Taxi drivers hey. Driving down Northbourne last night a copper pulled up beside me, gave me a very weird look, then proceded to CUT ME OFF!.... he then sped off, merged into a turning lane without indicating, then pull out of it and kept going straight. I should have gotten his licence plate number and reported him, but I was too busy swearing at him.
Spotted a nice Blue R33 GTST in civic and a Maroon one in Dickson, but it had ugly chrome wheels.
It must be the latest thing to do, Good Friday I was driving along Athllon Dr and a Cop nearly ran me off the road. I swear he took the clear coat off my front bar :D
Automatically went to blast him with the horn...figured i would same time and possibly money by letting it go.
(I think this shouldve gone in What ticks you off thread...cos thats what grinds my gears)
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3054931
Thats awesome Simmo.
Got an ETA on its return?
thanks man, not sure when itll be back yet, hopefully not too long i hope :whistling: . just steering it onto the back of the truck and having it move again has made me more impatient though heh.
spent quite a wwhile drooling over [YES-32R] at trojan, also spotted MKDR33 but ive been beaten to the spotted thread again hehe, good to meet you too man ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3055620
white four door r33 near civic yesterday.
also a black r33 with silver stripey tattoo bits in woden. i'd advise against parking next to the trolley return bays in that underground carpark - the trolleys don't have brakes, and the chaps collecting them don't care what stops them!
Edited by sigsputnik
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3062590
nice town you got here...
spotted a burgandy R33 last night at about 11ish on commonwealth av. I was in my dad's black ceffie.
passing thru canberra from syd. decided to stay a few days in Kingston.
so where you all at? there's so few imports here... and everyone drives riced up celica's??? wtf.
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3063324
You must not be looking to hard... i reckon i see more imports in Canberra than when i am getting around Sydney and Melbourne. A lot of the skylines are further out south. Northside well except for passing through to get out of Canberra there is no need to go there :P
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3063618
Spotted wingless silver R33 on Parks way 8.50 lastnight followed you from black mountain to Kings av bridge.
Aaahhhh that was you up my bum :) I'm ashamed to say but I actually thought your car was an old porsche, looking through my rearview mirror :( I'll be sure to wave next time I see ya
Also spotted R34-GTT last night on Hindmarsh Drive. Hey Mladz, did you go to the movies? saw you pull out of the carpark behind me at hoyts
Edited by R33Driftr
https://www.sau.com.au/forums/topic/30059-spotted/page/403/#findComment-3063925
