I spotted the yellow 332.. with a massively wide body on the back of a tow truck heading into belco from civic... after the tunnel.. niiiice..
yer thats fatass its nice as i think glen from esp bought the rolling chassis wit no motor from the previous owner. it used to have a 1000 hp motor in it
https://www.sau.com.au/forums/topic/30059-spotted/page/412/#findComment-3146012
Spotted mine with its hood up in the middle of hindmarsh drive with a blown cooler pipe yesterday >__< How bloody annoying that was...
thats fkn annoying hey! if you dont have tools best you can do is just jam it back on and hope that it stays on until you get home/to mates place.
https://www.sau.com.au/forums/topic/30059-spotted/page/412/#findComment-3148315
Spotted a silver 33 with its hood up in my girlfriends st in Calwell on the weekend. <snip> no addresses please dude! <snip>
That was me learning the hard way that you should always make sure the o-ring from the old oil filter hasn't stuck to the engine block, before you screw on the new filter. 4 litres of brand new Castrol Edge on the driveway, and much swearing that you probably heard from your GF's place.
Car was sent packing to the nature strip in disgrace.
Next time, can I come down to your GF's and change the oil on the new paving? :cheers:
https://www.sau.com.au/forums/topic/30059-spotted/page/412/#findComment-3151445
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
