Spotted a silver R32 GTr crossing Melrose DR on Hindmarsh sometime before midnight and a Silver S2 R33 on Erindale DR going towards Tuggeranong early morning sometime. (i was in Yellow Security car)
Edited by datto260Z
https://www.sau.com.au/forums/topic/30059-spotted/page/419/#findComment-3201670
Spotted and gave a wave to a passing black S2 33 as I was waiting to turn on to Hindmarsh drive around 7:45 this morning, also saw a white R32 that looked like it had had half of its back end set on fire from all the black soot on the back crossing hindmarsh going down melrose drive.
https://www.sau.com.au/forums/topic/30059-spotted/page/419/#findComment-3204609
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
