spotted silver 32, white 33 and red corvette at the Mobil servo in braddon
spotted Cejay cleaning his 'was-once-a-WRX-but-isnt-anymore' at the belconnen car wash and had a quick chat
and spotted me finding out why the heat shield around the turbo is named a heat shield... also i snapped a bolt on it when i was trying to remove it... good times
https://www.sau.com.au/forums/topic/30059-spotted/page/423/#findComment-3240596
7:40pm tonight, cnr Drakeford and Erindale Dr. Turning right from Tuggers onto Drakeford, I watched a white 33 with a white 'For Sale' sign and mobile number on rear windscreen give it a gutful and get a bit crossed up... if I were using bike terms I would have called it a 'tank slapper'.
I caught up side by side to give a thumbs up :D but you didn't look up :) I should have called the mobile hehe
https://www.sau.com.au/forums/topic/30059-spotted/page/423/#findComment-3242083
Yeah was good to catch up, and your car really wasn't as dirty as you thought it was :thumbsup:
https://www.sau.com.au/forums/topic/30059-spotted/page/423/#findComment-3243696
haha yea i'm pretty anal about the dirt, washed it again today :thumbsup:
Dropped my car off in fyshwick to have exhaust finished off and wandered around fyshwick for an hour, spotted a white 32 (driven by a guy with mad sideburns/mutton chops), white 33 with DTS Dyno stickers on it, the J-Racing 34 and a black 33 near shell servo all between 1pm and 2:30. Also i'd recommend Carline Exhausts in Fyshwick for anyone that needs exhaust fitting, was a bit iffy when i saw their shop (looks like something from the 70s haha) but the work was very good, very fast, very cheap AND they got that bastard of an exhaust sensor off!
https://www.sau.com.au/forums/topic/30059-spotted/page/423/#findComment-3247137
hahah! those would have been my mad sideburns. was driving around fyshwick collecting various bits n pieces to clean up the car a bit.
Just because you have epic sideburns doesnt mean your too good to wave back to us normal people :thumbsup:
https://www.sau.com.au/forums/topic/30059-spotted/page/423/#findComment-3247327
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
    • If the original NA ECU has a separate TCU then you are going to need to reroute wires that used to run between the trans and the TCU to the appropriate (1 to 1 equivalent) pins on the ECU. Other than that, it should work. Look up posts by @Kinkstaah on the subject.
    • So the stagea was a series 2 neo det with tiptronic auto. (I have the transmission aswell) and has integrated tcu in the ecu. I'm hoping to use the entire stagea ecu, engine and auto harness.
