RWKW.
I'm wanting more now though =(
I got my GPX dynoed ages ago. 101kw at front wheels, only mod air filter.
Been spotting heaps of skylines this weekend, too many to keep track.
More than 4 today.
one nice silver R33 GTST series 2 with a not common front bar in city.
Black R32 GTR or GTS-T with trust front bar turning into Curtin this morning.
White R33 GTS-T with AVS with NSW plate outiside BP in the city.
White R33 GTS-T in Fyshwick turning at bunnings.
https://www.sau.com.au/forums/topic/30059-spotted/page/442/#findComment-3395864
a20089, think I saw ya at the Charny shops this arvo just after Bathurst ended. I was parked on your left as you went past. If not, it was a similar GTR 33.
Na, I think you will find that was SUKA, he's got a 97 with the xeons and a slightly darker paint colour.
My car is in the garage getting another oil change.
https://www.sau.com.au/forums/topic/30059-spotted/page/442/#findComment-3395897
Saw you too!
Just before that i saw Michelle on Drakeford Dr
Where were you? I was right behind him.
Also a heads up for peeps heading out to Tidbinbilla, the road has been removed and is currently just dirt/gravel. It's not tooo bad but still thought I better give some warning.
https://www.sau.com.au/forums/topic/30059-spotted/page/442/#findComment-3397075
Cool, do you have another picture of your car, looked good. what front bar is it anyway?
I'm sure i have one around here somewhere, i'll send it to you if i do. Its the R34 Impul bar (well entire kit) incorporating a little wide body action as well.
Cheers for the compliment pal, always helps at a time like this.
https://www.sau.com.au/forums/topic/30059-spotted/page/442/#findComment-3399021
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
