Saw LadyBytes R32 in civic today. Creative parking btw.
Your federals are going to wear out if you keep using them for normal street driving though :D
Not so creative... I had Steady Eddy with me... he's good for getting the good car parks LOL actually, I have secure parking at work and felt nervous with it out there.
Federals are good for street... soft but not too soft... I think they're good for around 13000ish k's
https://www.sau.com.au/forums/topic/30059-spotted/page/444/#findComment-3415702
In an R32 GTR you can expect about the 12 - 13,000km from 595RS, which isnt to bad considering how soft they are, but the problem is that your slowly degrading the tread compound by driving them cold, they are designed to be driven hot, so the more you drive them on the street the less heat cycles your getting into them and in turn you might find that they go a little bit hard after a couple of thousand km's...
That said, if you wear them out you will need to buy more, so go for it, I'll be here when you need another set :D
https://www.sau.com.au/forums/topic/30059-spotted/page/444/#findComment-3416834
Spotted a whole bunch of police cadets learning how to direct traffic at the melrose drive intersection, opposite mcgrath ford in woden around 2pm today lol :D Spotted a Black r34 gtt later in gungahlin, too late to wave though.
https://www.sau.com.au/forums/topic/30059-spotted/page/444/#findComment-3416854
did you say hi to my mate for me? He'd be the one with the giant "i'm a fu*kstick" stamped on his forehead.
https://www.sau.com.au/forums/topic/30059-spotted/page/444/#findComment-3416885
Funny that, went past at 2:20ish and they were gone when they were actually needed with a ford broken down at the intersection causing all sorts of chaos with idiots cutting lanes to save a precious minute..
Also saw a wrx pinned by an undercover VZ just down the road too.
https://www.sau.com.au/forums/topic/30059-spotted/page/444/#findComment-3416905
Nah was trying to drive as "quietly" as possible past them lol, sux they weren't there later by the sounds of it.
https://www.sau.com.au/forums/topic/30059-spotted/page/444/#findComment-3416962
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
