Silver 33 with GTR Do-Luck spoiler in Civic around 4:30pm
Silver 33 on the Civic side of Barton Hwy around 5:30pm
Spotted a the same Red Ferrari twice (once in kingston and once on northbourne) about 30 mins apart. Not sure what model, maybe F355, had numbers on the doors.
https://www.sau.com.au/forums/topic/30059-spotted/page/447/#findComment-3447172
Spotted a red Stagea in Woden....with an R34 front! Very very nice.
The other day I saw a red Mitsubishi Legnum in Woden. From a distance it really did look like a red Stagea with an R34 front - is that what you saw?
I would also like to take this opportunity to state that Legnums are very cool. I'd love one, in the rare manual.
And red.
With an R34 front? :)
https://www.sau.com.au/forums/topic/30059-spotted/page/447/#findComment-3448294
Spotted a dark grey R32 GTR giving it a hit up Erindale Drive this morning and scaring the crap out of a lancer so badly he almost crashed into me changing lanes haha.
Also drove side by side this afternoon with a black S1 33 GTSt from Commonwealth Ave to Woden Hospital and no wave :)
https://www.sau.com.au/forums/topic/30059-spotted/page/447/#findComment-3448824
So, I was dawdling up Northbourne Avenue this afternoon about 3:30 when I see a yellow Ferrari F355 heading the other way towards Civic. I think - cool!.
About a minute later, I see a red F360 go past me the other way. I think to myself - cool! what are the chances of seeing 2 Fazzas in as many minutes in Canberra?
And then the floodgates opened.
The rest of the time I spent on Northbourne I saw going past me the other way it was Ferrari Ferrari Ferrari Ferrari Ferrari Ferrari Ferrari Ferrari Ferrari Ferrari.....
Naturally I was quite pleased :blink:
246 GT Dino and F430 FTW BTW.
I turned onto the Barton highway, more Ferraris, but starting to thin out.
About 10 minutes later coming back towards Civic on Northbourne there's still Fazzas on the road. At the lights at London Circuit I had a 328GTS on my right, a F360 Spyder on my left and a 512TR in front of me.
So where's the Ferrari show this weekend? :)
https://www.sau.com.au/forums/topic/30059-spotted/page/447/#findComment-3449535
Spotted Jules' widebody braving the elements on the Monaro earlier today. Spotted Stevie sans Skyline twice at Belco' Mall, lovely lady in tow. Also spotted a silver 33 GTS on Wednesday night at Stromlo Cycling Park, it's owner chatting with an RX7's owner. Anyone on here?
https://www.sau.com.au/forums/topic/30059-spotted/page/447/#findComment-3452717
Spotted a Red 32 right near the pedestrian crossing outside Subway on Emu Bank Road, got a wave and gave one back. I'm pretty sure the guy works at a place in Belco and has helped me purchasing the right products a couple of times(Don't wanna give away too much of where he works).
https://www.sau.com.au/forums/topic/30059-spotted/page/447/#findComment-3453062
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
