Spotted a Red 32 right near the pedestrian crossing outside Subway on Emu Bank Road, got a wave and gave one back. I'm pretty sure the guy works at a place in Belco and has helped me purchasing the right products a couple of times(Don't wanna give away too much of where he works).
Spotted a white R33 followed me the whole way from Woden, down the parkway and then turned off at Kambah.
https://www.sau.com.au/forums/topic/30059-spotted/page/448/#findComment-3453100
Spotted
Yesterday
Silver 33 Sedan heading Yass way on Barton Hwy around 5:30pm
Black 33 On Barton ACT side
Silver 33 GTR parked near BP woden with cameras around 5pm
White 34 Sedan on Athlon around 12pm
Also spotted some poor bastard blowing something in his reasonably new Peugot. He was parked on the side of Athlon (near woden) this morning with white smoke absolutely billowing out, idiot didnt turn off his engine, just put his hands on his head and start walking back and forth.
Edited by Baconer
https://www.sau.com.au/forums/topic/30059-spotted/page/448/#findComment-3453120
white GT-T sedan would have been Abo Bob & me
and yeah we saw the Pug too! It looked like the oil was all dumped on the ground and was burning and yeah how much smoke was there!!... dunno what happened exactly!! poor guy!
https://www.sau.com.au/forums/topic/30059-spotted/page/448/#findComment-3454355
on saturday i drove past a black 33 with red plates, female driver leaving the brand depot, then i parked adjacent to a blak 33, white rims, 40th aniversary badge.
then today i spotted a gunmetal 4 door parked in front of tuggers lifestyle centre/tuggers markets/good guys building.
https://www.sau.com.au/forums/topic/30059-spotted/page/448/#findComment-3454812
Hmmm wonder what Tuk Tuk (Mark) was doing at tuggers lifestyle centre :D
https://www.sau.com.au/forums/topic/30059-spotted/page/448/#findComment-3455473
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
