Was at the lights in front of the convention centre on Constitution Av this afternoon next to a black R32 - sorry I wasn't trying to snob you, my phone started ringing and it fell under my feet when I went to cancel it, I did wave as we drove of :D
https://www.sau.com.au/forums/topic/30059-spotted/page/449/#findComment-3469379
Tuesday 11:15pm: Spotted a white r33 s2 coupe in a rush overtaking me on tharwa road then heading into theodore, which was weird cos i wasn't going slow.... Hope you got to your emergency! (2 seconds sooner!)
I keep spotting a maroon r33 series one parked in theodore on the main road. Very nice.
https://www.sau.com.au/forums/topic/30059-spotted/page/449/#findComment-3472654
Also spotted the water truck twice today 3 hours apart but 500m away from the first spotting haha, lazy
Yeah saw you heading back to Murrumbateman around 6ish. Did you get enough in that last lot of rain to keep you going for a while?
https://www.sau.com.au/forums/topic/30059-spotted/page/449/#findComment-3475102
:laugh: i was in the work truck (if anyone sees a white guy in a mushroom truck, wave dammit!) so wouldnt of been me.
Was a bit of rain but not enough at my place, my work is 15km away and got a crazy amount in that area, the neighboring paddocks dams are completly full now
https://www.sau.com.au/forums/topic/30059-spotted/page/449/#findComment-3475352
Now there's a man that loves his R33 GTR's.. two of them.
Hey Davio, bring one (or both) of your cars to marques in the park, Don;t want my R33 GTR to be the only good looking GTR there :-)
I would like to bring both but I will be working to about 12 or so on that day, maybe i can turn up later?
https://www.sau.com.au/forums/topic/30059-spotted/page/449/#findComment-3475395
Here is the car that was spotted
https://www.sau.com.au/forums/topic/30059-spotted/page/449/#findComment-3475400
Was at the lights in front of the convention centre on Constitution Av this afternoon next to a black R32 - sorry I wasn't trying to snob you, my phone started ringing and it fell under my feet when I went to cancel it, I did wave as we drove of :)
No probs mate :( ! Couldn't even get into the usual car park this morning! had to go and park in some other evil one :laugh::D
https://www.sau.com.au/forums/topic/30059-spotted/page/449/#findComment-3475535
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
