Oops :D Sorry about that, wasn't being a snob! When? And what were you in? I was probably completely zoned out if it was after work haha
haha its all good, pretty sure it wouldve been after work. i think i was in a commodore, 380 or an aurion, i cant remember which.
https://www.sau.com.au/forums/topic/30059-spotted/page/474/#findComment-3752534
just a couple of cars to choose from there! haha
i saw a silver R32 gtr at glenlock this arvo at like 6:15, was couple of cars behind me but i was in a magna and totally not skyline related, i saw a white toyota chaser with gold rims leaving the air port this arvo, very nice
https://www.sau.com.au/forums/topic/30059-spotted/page/474/#findComment-3753698
Ah ok. Do you drive the maroon 32 I see down that end of the airport from time to time by any chance?
https://www.sau.com.au/forums/topic/30059-spotted/page/474/#findComment-3753805
nah, if you drive up the road to the right after you pass that maroon 32 mine is blue and usually parked up there :blink:
https://www.sau.com.au/forums/topic/30059-spotted/page/474/#findComment-3754420
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
