Oops :D Sorry about that, wasn't being a snob! When? And what were you in? I was probably completely zoned out if it was after work haha
haha its all good, pretty sure it wouldve been after work. i think i was in a commodore, 380 or an aurion, i cant remember which.
https://www.sau.com.au/forums/topic/30059-spotted/page/474/#findComment-3752534
just a couple of cars to choose from there! haha
i saw a silver R32 gtr at glenlock this arvo at like 6:15, was couple of cars behind me but i was in a magna and totally not skyline related, i saw a white toyota chaser with gold rims leaving the air port this arvo, very nice
https://www.sau.com.au/forums/topic/30059-spotted/page/474/#findComment-3753698
Ah ok. Do you drive the maroon 32 I see down that end of the airport from time to time by any chance?
https://www.sau.com.au/forums/topic/30059-spotted/page/474/#findComment-3753805
nah, if you drive up the road to the right after you pass that maroon 32 mine is blue and usually parked up there :blink:
https://www.sau.com.au/forums/topic/30059-spotted/page/474/#findComment-3754420
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
