or maybe she just wanted to be spanked cuz she was driving a 33 ???
Good call Gus :devil:
Curves! 33's have their own post code......... like yo mama
(jokes)
Curious tho ~ What's the ratio of girls driving 33's in comparison to 31,32,34 +35's ?
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/528/#findComment-4340058
Spotto'd Gus (I think) in Jerrabomberra today, and a Bayside blue R34 GT-t on Erindale Drive this arvo, and spotted Rumble in Braddon tonight, as well as a few other R33s and 2 R34 GT-R in braddon as well.
https://www.sau.com.au/forums/topic/30059-spotted/page/528/#findComment-4343277
Spotted a white R33 with black bonnet driving up Northbourne near Dickson... I was in stealth mode in the Audi :D
Also saw a whole heap of tossers driving round and some copper in an undercover white Falcon pulling over some crappy old car.
Looking forward to this crap being over and Flemington road opening again.
https://www.sau.com.au/forums/topic/30059-spotted/page/528/#findComment-4344296
Spotted Erica's GT Forrester " Mrs GT" and a whole bunch of others in Braddon. Most of the street is Domminated by parked Mustangs, a few Hot Rods and of course the Subaru wagons.
Still looking good J + E :happy:
Bayside Blue Phat 34 at QIX Fyshwick.
PS. Looked like your 31 was on the street Blueprint ?
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/528/#findComment-4344496
aww you didn't see my car Richard? :blink: I was only a few back from Bluprint
It was cloaked in invisibility, Did you have it switched to stealth mode again? I was probably looking at cute distraction at the time :happy: sowwy.
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/528/#findComment-4344941
Spotted a white 33 GTS-T last night at about 9.30 on Ballumbir Street in Civic. It had chrome rims, a black(painted, Im pretty sure) bonnet, lowered with a pretty blond in the passenger seat and a young fella steering. I think it was the same one I'd seen parked in Lonsdale Street earlier watching the 'Nats merriment. Anyone on here?
https://www.sau.com.au/forums/topic/30059-spotted/page/528/#findComment-4345043
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
