You'll keep girl! I got your inference.
Can a Nissan Pulsar do 170kmph? I'm fighting this one....proove it Constable Kenny
yeah it can my mate owns the black GTIR with the big front mount and is loud.. they hold there end up well. there a little rocket
https://www.sau.com.au/forums/topic/30059-spotted/page/530/#findComment-4352234
I think I may have spotted JD R33 (Sky? Blue R33) on the big roundabout near Kingston at St Clairs this morning... It's hard to wave whilst turning on the roundabout half asleep.
Yep, t'was me. :(
I think I tried to wave back, but it was early and I was on autopilot as well. White R33 with goldish wheels? I was probably checking out your wheels, wishing mine weren't so....stock.
I must look like one of the summernats blow-ins with the Vic plates, hopefully they'll be gone by friday.
https://www.sau.com.au/forums/topic/30059-spotted/page/530/#findComment-4353198
Yep, t'was me. :)
Yeh mate, White with Gold Volks.
Honestly, didn't pick the Vic plates. I picked 'Summernats Blow-in' purely because I had not seen your car around before.
https://www.sau.com.au/forums/topic/30059-spotted/page/530/#findComment-4353519
Thought they were Volks, but didn't get a good enough look. Very nice.
I'm having trouble imagining anything other than gold Volk GT-C's on this blue, although apparently I have appalling taste when it comes to wheels (e.g. chrome Starcorps on last skyline).
Can anyone suggest something nicer than GT-C's?
https://www.sau.com.au/forums/topic/30059-spotted/page/530/#findComment-4353680
Does anyone know who owns the Silver series one R33 Gtst that has great big blue 2Fast 2Furious style vinyls up the sides, a big Autobarn T wing, 17 or 18 mags, a monster tacho on the dash and number plates "KNGR33"?
It had Trojan Motorsport skickers on the rear quarter windows too.
I saw it last night and had a giggle to myself and thought "time to move on mate, the fast and the furious isnt cool anymore". :D
P.S. I apologise if the owner is on here, but seriously - its time to try a new look.
https://www.sau.com.au/forums/topic/30059-spotted/page/530/#findComment-4354524
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
