spotted a pearl white GTS4 yesterday arvo in nothrbourn i waved as i went past even tooted your a snob jks
spotted a dark green R33 today on markus clark near hobart pl i nodded as i walked in front of your car nice wheels
https://www.sau.com.au/forums/topic/30059-spotted/page/575/#findComment-4773776
SUNDAY
Spotted a white 33 coming down alkman drive going onto Ginninderra drive at around 4:30 THEN 10 minutes later
Spotted another white 33 coming from Ginninderra drive going down alkman towards maccas
Gave a wave to both, and received a wave from both. I was the white 33 with the 400R front bar and the white volks
MONDAY
Spotted a black r32 GTR going down northbourne ave at around 5:10
TUESDAY
Spotted a Maroon 33 with a S1 wing driving along side me on parkes way at around 8:50 in the morning (tried waving, but whoever it was wasn't looking)
Spotted another maroon 33 about 5 minutes later parked with someone in it next to the hotels/apartments on Edinburgh ave
Spotted that night at around 10:00, what i think was GTRkat in her white 32. i was turning right onto hayden drive. you were turning left onto belconnen way. I gave a wave, not sure if i saw one back.
https://www.sau.com.au/forums/topic/30059-spotted/page/575/#findComment-4776888
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
