Was getting dark when I saw it, but looked like this sorta colour: http://blog.niot.net/en/tag/gt-r+v-spec/
Had the xenon lights, looked sweet as.
Just realised the link has loads of diff colours, neway looks like all the red ones lol. It was a bold slightly dark red.
Edited by 33Sedan
https://www.sau.com.au/forums/topic/30059-spotted/page/576/#findComment-4778594
oh sweet jesus that's pretty much it
https://www.sau.com.au/forums/topic/30059-spotted/page/576/#findComment-4779232
Spotted a black R32 GTR (I think, was a quick glance staring into the sun) turning off from Lady Denman and heading onto the parkway going towards Tuggers. I was heading the opposite direction, was between 4:30-5ish.
My Petey also said he spotted a dude driving a pink R33 in Tuggers yesterday.
https://www.sau.com.au/forums/topic/30059-spotted/page/576/#findComment-4779383
Just spotted a dark grey/black R33 Pull out in front of me turning off gladstone st in fyshwick :D made me use the brakes in the van! (which don't really do all that much)
My apologies, :yes: misjudged the truck in front of me. Just got the 'mistress' back and giving it a bit of a run
https://www.sau.com.au/forums/topic/30059-spotted/page/576/#findComment-4780567
HAHA cool. it was someone on here!!!
its a pretty common thing in fyshwick... everyone drives crazy when they get into that subburb for some reason
Cos they feel guilty getting $100 worth of porn, race in and get out!
Edited by 33Sedan
https://www.sau.com.au/forums/topic/30059-spotted/page/576/#findComment-4783476
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
