Spotted JD this morning in the V Spec... You drove past me but don't think you recognized the new daily driver.
I thought that was you in the white sedan and was nearly going to lean on the horn, but there was a commodore between us which may have been a bogan transporter, so I didn't. :P
So, what is this new beast? I didn't get a good look.
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4815881
Spotted 2 guys on the manaro heading fyshwick way, one in a white commo ute, and the other was some chrysler suv thing, seemed like they were racing.... they were weaving in and of cars and using the side walls, was crazy, they were prob going over 150 in the 80 zone. Very fishy.....
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4815895
Haha, i did notice the possible bogan transporter... You would have been stuck at the lights with them getting out of the car.....
The new beast is a '93 Subaru Liberty Heritage Auto.. Ruff on the outside but drives smooth as. I needed something that would allow me to park in Civic and manuka without worry of theft etc.. As in, I'd still be highly concerned about it being taken, but its better it than the 33.
Edited by sfrizza
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4815920
wtf when I'm not in the 33, I see heaps of other skylines, but once I sit inside her, no1 is around to be seen >.<
Mustn't see others/be seen when I'm in my own little world...hahaha considering how often I'm on my way to Fyshwick every morning.
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4816013
Haha that's what happens to me too. The audi gets spotted much more between here and CC than the GTR does :)
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4816065
haha, what kinda wheels u got?
They looked like some kind of 5 spoke chromes from the distance I was at, assumed it may have been u coz I can't think of anyone else with a white 33, other than Reece (not turismo)
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4818311
MMmm, my rims aren't chrome apart from the lip/dish
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4818319
spotted a white R33 on Long Gully Rd about 4pm... gave a wave not sure if they saw
and a silver R33 stopped outside the car yards in Phillip opposite Marist... guy in drivers seat, blonde girl outside car on passenger side.
https://www.sau.com.au/forums/topic/30059-spotted/page/581/#findComment-4821281
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
