Can't say I've noticed that! With my new tyres and some fixed suspension my baby is holding to the ground like glue!
Spotted a gunmetal (or was it silver??? too early in the morning!) 33 turning from Ginninderra drive onto the GDE this morning on my way to work. As per usual when I make spottings, I was in the Audi :down:
https://www.sau.com.au/forums/topic/30059-spotted/page/590/#findComment-4883246
Hmm well the tyres are nearly two years old with about 20,000km on them, i think.. Although, Kat, are you running the RS-R's, mine are only the SS's..
Nope I be running Bridgestone RE55's.
Funny though, you get used to how your car is feeling, I knew it needed work but I didn't quite realise how bad it was until I remembered how good it could feel when I got it back. I think that makes sense... Oh well it's Friday and my brain has officially shut down!
https://www.sau.com.au/forums/topic/30059-spotted/page/590/#findComment-4883943
Also W1ngnut and someone in a gunmetal 32 with an SAU sticker that I haven't seen/met before both on Monary hwy this morning.
That was me :P - BTW it's Silver not Gun Metal (its a bit dirty at the moment though).
Haha spotted Trozzle and Bullet32 on Monaro this morning. Does anyone else think the roads might have a lot of dust/dirt on them? I felt like i had very low grip on the way to work and I don't think the 595's are due to be replaced already..
It was very slippery on the hwy this morning, its the left over crap from dirty rain on the surface of the road after the water dries up.
P.S. I love the wheels on your car! :devil:
https://www.sau.com.au/forums/topic/30059-spotted/page/590/#findComment-4883999
RHGY? Did you cap it before FW? wait, wtf....
Dead guy? wowowwwz explain
by Rh. I meant rush hour. wasnt sure if i wasnt meant to mention it. haha
and yer after everyone from rush hour went to the strip club, my friend and i (we both arnt 18) were driving back home and we saw heaps of cops taking pics of some dead guy.
has it been on the news yet?
https://www.sau.com.au/forums/topic/30059-spotted/page/590/#findComment-4884648
Your running RE55's for the street? :D
https://www.sau.com.au/forums/topic/30059-spotted/page/590/#findComment-4886294
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
