Spotted a very tidy white 32 GTR (Autostyle sticker) and not far from that a not so tidy white 32 GTS-t with black bonnet and front bar near Dan Murphy's tuggeranong. Credit to the GTR owner inside and out. I cant understand skyline owners who let their rides deteriorate like the GTS-t. Especially a 32 FFS...
https://www.sau.com.au/forums/topic/30059-spotted/page/606/#findComment-5071161
No one is allowed to judge me on the outside of my car until it is painted. LOL
https://www.sau.com.au/forums/topic/30059-spotted/page/606/#findComment-5071186
Sorry Matt :D a lil judgmental when I see a 32.
If it was a 33 or maybe 34 I wouldn't bother commenting. Nothing beats the hard lines, performance and the real driving experience of the 32 IMHO....
(quickly paddles backwards)
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/606/#findComment-5071260
31 beats all.
https://www.sau.com.au/forums/topic/30059-spotted/page/606/#findComment-5071298
Spotted a silver R33 at about 6:30pm on Canberra Ave heading into QBN, just seemed to be parked on the side of the road and I couldn't see anyone in it hope it hasn't been stolen.
That was mine. Water got into my map sensor somehow. My mate put a new map sensor in my ECU and it's running fine again thank god. Spotted a silver R33 going past while I was working on it, looked like he was having a laugh at me but not sure. Know I saw a couple of commodore drivers getting a kick out of it.
https://www.sau.com.au/forums/topic/30059-spotted/page/606/#findComment-5080684
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
