Spotted Kat today from Gungahlin lights up, then up the barton highway. I was on the green ninja.
Love the sound of your motor. Gave you a wave but you wouldnt have seen me through the mirror visor.
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5104287
Spotted a white 32 4 door with a black boot and fuel cap cover driving from holy family all the way to Gordon direction driving like a granny around corners but would give it a hit (if they manage to be in the correct gear exiting the corner) on the short straight bits...then I believe a black 34 was up my arse while I followed the 32 who then followed them further when I turned off.
And wow my grammer is terrible haha
ps I was in the black ute
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5106075
Blue 34 GTR on Yamba drive near the hospital, was stuck a couple of cars back and couldn't get in closer for the wave :blush: also I believe ZANE this morning as he went up the Hindmarsh exit ramp from Monaro heading south...I was on other wise of the highway
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5106330
Saw a charcoal grey R32 GTS-t at the RTA carpark in Queanbeyan today (that carpark is designed to break cars i swear) female driver, looked pretty stock save for the exhaust. If the owner is on here i was parked next to you in the white 260Z.
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5107785
Blue 34 GTR on Yamba drive near the hospital, was stuck a couple of cars back and couldn't get in closer for the wave :P also I believe ZANE this morning as he went up the Hindmarsh exit ramp from Monaro heading south...I was on other wise of the highway
yay i got spotted!!! but i didn't even see you lol
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5108256
That was my car but a friend is borrowing it due to hers overheating.
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5110635
Nah mines silver and no GTR kit. I only go that way if Captains Flat Road has been freshly grated, otherwise I go the long way around or I take my falcon.
I have seen yours, but not for a long time. do you go out that way often?
yeah, once you are past the dirt section out the back of captains flat, the road is awesome :down: long straight tarmac right through to braidwood! it cuts my travel time to the coast down if I go that way - just need the dirt section sealed...
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5110920
I used to, not so much anymore. I normally take my green EL falcon but sometimes I just can't be bothered putting up with slow. The dirt road is REALLY fun if it's grated but the moment it rains it's just. Not good. I used to drive that road every night at about 1am. I used to get very sideways, it helps having your headlights where your going, rather than off the road.
https://www.sau.com.au/forums/topic/30059-spotted/page/610/#findComment-5111764
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
