Inline did my rack bushes... Which ended up putting my HICAS way off (weird feeling it coming on in a straight line!). So I had it removed or rather locked with a Tomei kit... I thought it made the steering heavier, particularly at lower speeds, but decided it was in my head LOL. Now I'm not so sure!
https://www.sau.com.au/forums/topic/30059-spotted/page/619/#findComment-5197101
You need the fins removed from the rear section of your ps pump
https://www.sau.com.au/forums/topic/30059-spotted/page/619/#findComment-5198635
Spotted a black R33 GTS-T turning into Mitchell from Gungahlin Drive this morning.
And further down spotted what looked like a purple R33 of some description. Couldn't see the whole car with the big grey wall in the middle.
https://www.sau.com.au/forums/topic/30059-spotted/page/619/#findComment-5201014
not an easy job. best done when the turbos are off (that;s when I did mine). when you are doing it, its best to remove the enitre rear pump wheel that holds the fins, the rear steering lines and the Hicas controller that sits on the chassis rail under the plenum. you'd e surprised the difference this makes when changing an oil filter!
the steering loading up can be caused by the steering wheel not being aligned properly with the locator, or you may need to reset the system (process of reversing a couple of meters, then the same forward - there is a DIY on here somewhere).
https://www.sau.com.au/forums/topic/30059-spotted/page/619/#findComment-5201035
Spotted the Purple R33 turning into Mitchell! And spotted me driving my Grey / Black R33 in traffic on the GDE!
https://www.sau.com.au/forums/topic/30059-spotted/page/619/#findComment-5201130
Passed a black 34 at the bottom of Coulter Drive on Sunday night ~11.50pm... they pulled off into Weetangera afterwards. Anyone on here? :) Didn't think to look if it was a GTR or not, but I'm curious!
Yeahh, that was me, its a GT-T :D you were the Grey 33 right ?
https://www.sau.com.au/forums/topic/30059-spotted/page/619/#findComment-5204017
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
