trozzle have you sent the turbo back to hypergear? Ive seen a few of them and never really been very impressed with the quality especially when simple things like bolts are barely metalic or magnetic lol
garrett althe way my friend!
ive been spotting a few lines including a nice black on black 33 gtst in phillip there was also a very clean white 33 gtr at ESP Friday night and James at ESP today too haha
https://www.sau.com.au/forums/topic/30059-spotted/page/637/#findComment-5465644
I'll be removing it and sending it back to be looked at.
He has enough customers with proven results to show that even the lower quality products still work without issues. The main problem at hand is that there's a very good chance that the wastegate issue I'm having was inadvertently caused by ESP when they dismantled the (admittedly dodgy) wastegate adapter plate and then put it back together for no apparent reason.
Either way, we'll know the issue once it's off, and I'm sure that Hypergear tend to warranty issues a lot better than Garrett would, or even be able to lol
https://www.sau.com.au/forums/topic/30059-spotted/page/637/#findComment-5466088
bahahaha, now someone else knows where I live! First it was w1ngnut when I was at my parent's place, now you! lol
Don't spose you spotted me under the car swearing my head off?
I know where you live... :happy:
https://www.sau.com.au/forums/topic/30059-spotted/page/637/#findComment-5470139
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
