There was a green skyline (nfi what it was, andrew might know lol) that had been pulled over on the Monaro a couple of mornings ago. It was one of those pearl cars where it looked green & then pink.
that kinda sounds like the chameleon R33 that is getting about.. it seems to show up at the nats every now and then as well...
think it's gunners based..
https://www.sau.com.au/forums/topic/30059-spotted/page/644/#findComment-5551047
Pretty sure it works at dynotune or something in belco... always see it there... trying to hide :D
https://www.sau.com.au/forums/topic/30059-spotted/page/644/#findComment-5551462
Spotted a black r33, near spitting image of my car driving along William Hovel Drive this morn (South bound) around 9:10am.
Also spotted my r33 still sitting at home depressing me cos it aint going. Sux most cos ALL the major work want and need done to the thing is done. Just is small aesthetic things (except for the leak of water in the boot).. Runs and drives perfectly, looks great, sterio is all sorted, alarm system is all adjusted bout right now also... But got the fuel pump issue pissing me off now (partially it not working, partially my lack of time to work on it and try to sort out what the hell is wrong so I can fix it...)
https://www.sau.com.au/forums/topic/30059-spotted/page/644/#findComment-5551730
At least urs can move...
But yeh tis a sad issues also, both quite frustrating. I need more time to work on this and sort it out. And then hope all will be better soon....
Ahh, but today at lunch I removed the vac line to the actuator, and still couldn't make REAL boost....barely made it to 1 bar...if everything is working correctly, I should have shot through to overboost cut quicker than you can say wtf
I too am going to go insane with this shit lol
https://www.sau.com.au/forums/topic/30059-spotted/page/644/#findComment-5552217
haha...well my cat already (and has been since I got the car back after work was done for this power) makes a horrid metal vs metal vibration sound, but I'm fairly sure that it's the heat shielding on the top....I may or may not remove the exhaust from the front pipe and go for a VERY short drive this arvo to see if it's all good without that one there, but I don't know if I cbf risking it lol....
It's a ceramic cat of some kind...only strange thing about it is that it managed to flow 294.4rwkw the other week :\
https://www.sau.com.au/forums/topic/30059-spotted/page/644/#findComment-5552286
Well failing my cat-less test this arvo, it will be going into autotech next monday for pressurised smoke through the intake test to find any leaks...and if I haven't tried dropping the cat yet, they'll also chuck her on the dyno for a run with only the dump pipe.
If it's the cat, I don't give a shit lol. Just means I gotta drive it a bit softer for a while til i replace it like I've been meaning to :D
And after speaking to Stao (Hypergear), he's assured me how unlikely it is for anything to go wrong with the turbo to cause this, short of damaging the wheels themselves - which is amazingly unlikely too. helps for peace of mind, love that guy's customer service.
https://www.sau.com.au/forums/topic/30059-spotted/page/644/#findComment-5552322
hahaha, yeah when I came up beside you I wasn't sure if you realised who I was from here....so I gave you a really ghey wave and then felt like an idiot rofl
yeah i wasn't quite sure of what kind of friendship you had in mind!!! :D
...not that there is anything wrong with that!
https://www.sau.com.au/forums/topic/30059-spotted/page/644/#findComment-5552405
