About an hour ago I drove past a black 33 parked across two lanes facing the wrong direction on drakeford drive with the car jacked up looking like the spare wheel was being put on and cops directing traffic around it.... Weird... Anyone know what was up with that?
https://www.sau.com.au/forums/topic/30059-spotted/page/687/#findComment-6012517
Spotted a black R34 V-spec II NUR in Kingston!!!!!
The owner was the original owner of a black R32 GTR (Aus delivered) with the numberplates JUN. He used to frequent these forums and Friday night gatherings back at the museum, not sure if he still does or not.
It's in Kingston a fair bit because he owns a fairly large business there :)
https://www.sau.com.au/forums/topic/30059-spotted/page/687/#findComment-6014675
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
