I've done it myself and it makes me mad. The fools who take off and then stop suddenly at give ways :rant: pure poor judgement!
:( .........................broken in 2 or 3 spots
Hopefully there's a replacement front bar not too far away and then paint, all adds up to be costly.
https://www.sau.com.au/forums/topic/30059-spotted/page/693/#findComment-6062176
i saw a black stagea exiting the bottom woden carpark tonight, kudos to lifting the boom gate up lol!
HAHAHAHAHAHAHAHHA!!!!!!!!!!!!!!!!! well to be honest with ya i got to the gate and couldnt find my card so i backed back, got out and checked all my pockets etc and then thought fark it so i lifted it and then had a very hairy exit in the wet hahaha. well spotted mate :thumbsup:
https://www.sau.com.au/forums/topic/30059-spotted/page/693/#findComment-6065781
we end up driving out after you anyway. i dont see why they have them down if it doesnt cost after 6 or something like that!
https://www.sau.com.au/forums/topic/30059-spotted/page/693/#findComment-6065820
Haha I nearly did the same in a Sydney car park.
Lost my ticket at a cafe and it was going to cost $65 to get a new ticket.
Went down with a hoodie and saw about 50 camera's
Decided to go check the last place we were and it was sitting on the ground in a pile of leaves.
So lucky
https://www.sau.com.au/forums/topic/30059-spotted/page/693/#findComment-6066434
Yeah its actually pretty funny.
Not one of those movies you laugh the whole way through but it is one that keeps you entertained the whole time.
Anyone seen that Red Dog movie yet?
**Spotted a grey 32 at Woden last night with a big racing dot on it with the numbers 32**
Edited by Kasko
https://www.sau.com.au/forums/topic/30059-spotted/page/693/#findComment-6068253
Red dog was pretty good I enjoyed it
That R32 is turismo (reece) and mine was in the car park hiding :)
https://www.sau.com.au/forums/topic/30059-spotted/page/693/#findComment-6069336
Spotted what I think was a silver R33 (Maybe R34) in my rear view mirror about 15 minutes ago on Ashley drive.
From what I saw it was pretty tidy but the annoying blue headlights made it difficult to see much.
https://www.sau.com.au/forums/topic/30059-spotted/page/693/#findComment-6069380
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
