Ive got a black evo 8 and a gun metal grey r32 gtr sitting outside my house right now.
Can any of you guess who it is?????????????????????????
Well???????????????????
Come on????????????
Takeshi Nakazato and Seiji Iwaki?
https://www.sau.com.au/forums/topic/30059-spotted/page/697/#findComment-6096534
