Yeah that's it! Except I'm pretty sure he had a normal spoiler like mine (not yours :P )
I really can't decide whether I like those silver bits or not. They look ok in those pics but at first glance on the road I thought he had bits in primer or something lol
https://www.sau.com.au/forums/topic/30059-spotted/page/699/#findComment-6106033
Spotted 32 XAA-109 who was driving like a complete and utter tosser.
Next time you swerve into the right lane with no indication when someone is about to overtake you, then attempt to make them rear end you with my pregant wife on board, will be the last time you drive.
https://www.sau.com.au/forums/topic/30059-spotted/page/699/#findComment-6107008
Ill keep an eye out and give him the finger for you!
What colour?
https://www.sau.com.au/forums/topic/30059-spotted/page/699/#findComment-6107048
Thanks guys.
Hope to meet some of you at future events.
I am going to go check out JDM Fest on Saturday.
I am biased to the R33 too. LOL
Hope you live Northside ............. lol
https://www.sau.com.au/forums/topic/30059-spotted/page/699/#findComment-6109688
