I once saw a r32 gts-t towing a trailer full of furniture...would have been a fun drive with teh little rb20 lol
Spotted mr Valve train rattle again this morning, followed by a grey R32 with BBS or Work meshies
You so stealth.
https://www.sau.com.au/forums/topic/30059-spotted/page/701/#findComment-6136677
Spotted a white on white R33 in the PJ's car park in tuggers last night, seen it around before, has a white weather strip along the windshield
Had some tasty Jap wheels but cant for the life of me remember what they were.
It was an R33 done correctly
https://www.sau.com.au/forums/topic/30059-spotted/page/701/#findComment-6137131
I can't fathom how anywhere can have an above average schnitzel... I mean seriously, they're just a f**king crumbed and deep fried piece of chicken... Zierholz in Fyshwick however seems to use better quality chicken and puts fancy shit in the batter
https://www.sau.com.au/forums/topic/30059-spotted/page/701/#findComment-6137814
Lol. Tuggeranong Leagues club. A small establishment hidden within the 'Four Seasons House' complex.. sort of underneath the Lakeview restaurant. Safe within the normal lunching hours.. but stay clear of the local wildlife's watering hole afterwards.
buffys = buffaloes. (Tuggeranong Buffaloes Rugby League)
https://www.sau.com.au/forums/topic/30059-spotted/page/701/#findComment-6139540
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
    • Do this, and we'll have a resource right here.
    • "Hybrid" is a meaningless term. I could not tell you what the vendor of that turbo means by "hybrid".
