Spot on :thumbsup: your psychic.
Psychic? How did you Know?
I am also a Cancerous Crab.
Keep Spotting a Black R33 with Silver/Chromish Rims, turning right onto Belco Way from Bindubi St, approx 3:45pm on the way home from work.
https://www.sau.com.au/forums/topic/30059-spotted/page/703/#findComment-6146804
Thanks for the recommendations, everyone!
I ended up going with Robert from A Towing Connection
$88 delivered to my door. Beats the hell out of the bloke in Mitchell who was going to charge me $170 "off the books" and "over $250 with a receipt". I LOL'd hard.
Good Idea, Sinista32, I was actually going to leave it there overnight :P and thanks for pulling over for a fellow SAU bloke in need :)
https://www.sau.com.au/forums/topic/30059-spotted/page/703/#findComment-6147321
