We parked next to a silver 32 in one of the Canberra Centre underground carparks tonight, maybe Zane? Had 32 GTR wheels and a GTR grille.
Hopefully not from the Skyline but something there had a pretty nasty oil leak, big pool and dripping trail following where the car left.
https://www.sau.com.au/forums/topic/30059-spotted/page/710/#findComment-6178013
if you were in what I though was your (husbands?) S3 right out the front of the elevator doors, then yes, twas me. Oh and that GTR grill was yours, finally got it painted.
was the oil in the car park after I left? I just went and checked underneath my car and it's not leaking, so not mine yay!
https://www.sau.com.au/forums/topic/30059-spotted/page/710/#findComment-6178128
Spotted, a $1,000,000 (or there abouts) R34 on Ebay.
Not a lot needs to be said about this except no wonder the steering wheel has a plastic cover!
http://www.ebay.com.au/itm/Nissan-/300645991554?pt=US_Cars_Trucks&hash=item45ffe5c482#ht_500wt_1413
https://www.sau.com.au/forums/topic/30059-spotted/page/710/#findComment-6179193
You don't pay a percentage on motor vehicles - it's a fixed price, $40 or something
What the fark.
So some flamin mongrel can sell a car for $1,000,000 and pay LESS in transaction fees than if I sold my push bike for the amount I'd like to get for it.....domokun.gif
https://www.sau.com.au/forums/topic/30059-spotted/page/710/#findComment-6179632
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
