Yes I too spotted the yellow wingless 34 in Qbn, fully equipped with 'p' plates and doing his best to attract attention to himself with a little wheel spin between gears ... Nice looking car though.
I also copped an eyeful of the black 33 (i think gold wheels) referred to above, it was near the park at the time, looked very nice from where I was ...
https://www.sau.com.au/forums/topic/30059-spotted/page/754/#findComment-6499315
Yes I saw the 34 do a cute skid in between gears after a green lights.
Yeah sounds about right, the black 33 looked pretty clean as I drove past it
https://www.sau.com.au/forums/topic/30059-spotted/page/754/#findComment-6499335
Yes I've seen him too funnily enough chirping it through a roundabout in QBN. I don't think he relises that its a non-turbo...
Anyway, he is sure going to cop a fine from the fuzz soon if 3 peeps on here have already seen loss of traction from a look at me yellow skyline with white wheels and a P plate.
https://www.sau.com.au/forums/topic/30059-spotted/page/754/#findComment-6500128
As long he stays over the border so there's no chance of mistaken identity! lol
https://www.sau.com.au/forums/topic/30059-spotted/page/754/#findComment-6501001
