I didnt spot the Banana at your work today shell
and btw...I should be working in the same street as you :ph34r:
Oh awesome! Can you work the same hours so I can get lifts? :D
Nah I usually park on the premises behind the gates so you wouldn't see it from the street. It's only on the street if the sales reps have stolen all the spots.
https://www.sau.com.au/forums/topic/30059-spotted/page/760/#findComment-6531967
Spotted THE34T in traffic on Canberra ave yesterday arvo.
And a silver 34 with white enkei RP01's or similar in fyshwick at lunchtime today
Thanks mate .... I was just about to go with the green light when I spotted a glimpse of your grill in my side mirror, I looked around enough to see the front of a black Stagea, attempted a feeble wave and left the lights ... Seems like it was all in about 2 seconds.
https://www.sau.com.au/forums/topic/30059-spotted/page/760/#findComment-6539384
Keep spotting a gunmetal grey R32 GTR complete with Federal Tyres sticker and SKY32R plates outside my work in Woden.
Also spotted an orange R33 with a girl driving it, not sure of anyone else has seen it???
Edited by Amaru
https://www.sau.com.au/forums/topic/30059-spotted/page/760/#findComment-6540739
R32 is Reece
And no, nobody has seen her ever!
https://www.sau.com.au/forums/topic/30059-spotted/page/760/#findComment-6540918
Keep seeing a banana 34 GT-T heading down tharwa towards drakeford at around 735am
I'm in the noisy white commodore going the other way
That's me dude...
What colour is the bombadore?
https://www.sau.com.au/forums/topic/30059-spotted/page/760/#findComment-6540949
