Spotted a black R33 on Majura at about 8am this morning.
Waved but I got nothing.
I've spotted him every morning and dont think hes on the forums
I haven't even thought about it really. Mechanically it's quite good, have to see how it cleans up.
yeah but you could always sell it before spending the time to clean it?
https://www.sau.com.au/forums/topic/30059-spotted/page/785/#findComment-6664461
I need to give it a good clean inside and out. I don't have time to f**k around before year is over.
Unless your interested in which case make an offer. Otherwise I'll get to it when I'm ready, in no rush.
https://www.sau.com.au/forums/topic/30059-spotted/page/785/#findComment-6665167
Spotted a r33 gtst which was pretty much next to me from Woden to Monaro Highway!
Also spotted Kat walking to work from the parking lot!
I really dont know what to offer as the last nx i brought i got for $500!
You dont need any more cars. OR bikes. Or anything.
https://www.sau.com.au/forums/topic/30059-spotted/page/785/#findComment-6665693
Spotted a tidy white 34 GTT a few cars ahead of me, northbound and weaving through traffic on the parkway at around 7:45 while on my way to work this morning.
Was hoping to catch up and get a closer look but parkway traffic is full retard......
https://www.sau.com.au/forums/topic/30059-spotted/page/785/#findComment-6666324
This could be me, I work in dickson and drive an R33 :) Usually going into dickson at around 7:50-9:00.
Well hello and welcome!
Chuck a sticker on his car.
He will soon join
You didn't get stickered did you? :P
https://www.sau.com.au/forums/topic/30059-spotted/page/785/#findComment-6666510
Haha was off to get coffee. Choccie shop rocks!!
PM incoming.
https://www.sau.com.au/forums/topic/30059-spotted/page/785/#findComment-6666589
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
