Spotted Black Stag with green rims at Onasis Take away in Fyshwick.
Was getting an E+B and coffee for Breaky.
and also a mates white HCR 32
a given I spotted a number of Skylines at ESP this morning too :thumbsup:
I dare say that if you saw a white 33 that would have been mine.
https://www.sau.com.au/forums/topic/30059-spotted/page/792/#findComment-6688720
Defs tomorrow - for got to take them with me. But have put them in the 34 as I'll be dropping by again.
You got greenbacks ready to go :)
yeah send us a text when you find out and ill come round with the coin
https://www.sau.com.au/forums/topic/30059-spotted/page/792/#findComment-6688750
Yes - very nice.
Glenn was on it first thing this morn. All fixed ?
Yep :D Tested the 4wd by giving it a nice launch down at woden. The poor SV6 that had been trying to get me to drag him didn't have a chance :closedeyes:
Turned out that it was the TPS cracking the shits along with other things, so Glen worked his magic and all the problems went away
https://www.sau.com.au/forums/topic/30059-spotted/page/792/#findComment-6689073
Awesome - yeah. Good to be less complex.
Could've been a LOT worse :thumbsup:
Although 4wd full on all the time you would have climbed hills with some extra ground clearance - LMAO
Txt sent Anthony :D
:ph34r: BTW - wouldnt try that against Glenn's FG.
I think alot of people will have there ass handed to them on a plate.
https://www.sau.com.au/forums/topic/30059-spotted/page/792/#findComment-6689138
Oh yeah, spotted Shell I think (or another yellow R34 GT-T with black/dark wheels) turning from Drakeford onto Athllon yesterday arvo, around 6pm.
Shorty spotted you too Shell around the same time. At least she thinks it was you.
https://www.sau.com.au/forums/topic/30059-spotted/page/792/#findComment-6690549
Spotted a couple of 33 GTR's around my neighbourhood (Banks -- so; 'hood') during a leisurely stroll (Banks -- so; sprinting away avoiding thrown glass bottles and children).
One (white) was just parked in an open carport :wacko: , and the other (light purple w/ pearl may not have been a GTR) was being fixed up in a garage.
https://www.sau.com.au/forums/topic/30059-spotted/page/792/#findComment-6691112
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
