spotted three traffic crashes on my way back home to the south, when i drove past at all stations the cops stared at me like "if i wasnt attending this shit i would have pulled you over".
spotted a black stag in Woden then again in Mawson
https://www.sau.com.au/forums/topic/30059-spotted/page/802/#findComment-6722843
as i was exiting the richardson roundabout, i think i went over an oil patch and my car went sideways freaky shit. then in he middle of the struggle to gain control I spotted a black r34.i would like to thank the guys at fifth gear, otherwise would have panicked and written my car off
https://www.sau.com.au/forums/topic/30059-spotted/page/802/#findComment-6724137
