Yeah was disgraceful.. wheel spin into slamming on the brakes before plowing into a bus.. he just swerved into oncoming lanes without any care in the world.. p plate.. looked like he'd crashed before.. makes us all look bad..
With a bit of luck a kangaroo of karma will fly thorugh his windscreen kick him in the face. Speaking of kangaroo's i escorted one down outrim ave calwell this morining when i was on the way to the gym. Had my hazards on going about 30 with a kangaroo infront of me. Got some wierd looks from oncoming traffic.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/905/#findComment-7141344
f**k I would have sat behind you with my hazards on too!! I was got to Calwell around 7am ( to do some work for my grandad ) then mum drove it back to Yarralumla,
every skyline I see doesn't seem to be on SAU :(
Edited by ..::R33GTS-T::..
https://www.sau.com.au/forums/topic/30059-spotted/page/905/#findComment-7141734
this was 5:40am btw
https://www.sau.com.au/forums/topic/30059-spotted/page/905/#findComment-7141814
Had a 60 sec double spot!! :yes: pretty excited about that ....
at 11.55am today on Isabella Dve, heading towards Tuggers, a silver R33 S2 .. looked clean but we were both doing 80 in opposite diresctions so didn't see too much :closedeyes: .. then 60 seconds later (heading in same direction) a black R33 S1 (I think wingless) again going in opposite direction whilst I'm ploughing into a roundabout.
https://www.sau.com.au/forums/topic/30059-spotted/page/905/#findComment-7143060
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
