butt failed
Shaun not Shuan - Doh !
+ you forgot Shorn and Shawn
Huge butt fail - like ghetto butt fail :(
Shawn was the first one - you butt failed ! Never seen Shorn :O I guess I forgot Shawjn (silent J) :D
Edited by RosieR34
https://www.sau.com.au/forums/topic/30059-spotted/page/909/#findComment-7148471
Spotted Silver 33 GTS-t with a minor overheating issue on Athlon last night around 9pm
Stopped to lend a hand but left just offering advice :thumbsup:
Flush properly
Make certain thermostat is in correct way (replaced that day)
Use Coolant
Do with heater on full
- is water pump pumping ?
Bleed air off before driving, if possible
Check water level after driving for a while
Oh - it was a relatively new Rad as well.
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/909/#findComment-7149234
Black R35 GTR in the city about 2pm parked outside bags to go on Bunda street (ACT plates)
AND
Silver lamboghini gallardo, also on Bunda street about 1:30pm - had the top down and looked like you could fry an egg on the drivers bald head!
the only way you can afford a lambo at a young age is if you win the lotto....
its always the old bald guys driving expensive cars...
when im retired ill be owning some insane supercar just for fun, then ill get a heap of plastic surgery so I don't look stupid driving it......
https://www.sau.com.au/forums/topic/30059-spotted/page/909/#findComment-7149421
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
    • I spotted a black C34 in Mittagong this morning!
