Be carefull letting out secrets of the 'experienced' Richard, we will soon have a lot of young male 'Line drivers getting around with erect nipples and not so 'johnsons' .... :yes:
I think a rap/poem is needed for erected nipples and not so johnsons.
https://www.sau.com.au/forums/topic/30059-spotted/page/910/#findComment-7149628
Richard is da man
For experience and advice,
If he tells ya somethin'
He don't have to say it twice ...
He speaks from a well worn road
Of years of workin' it out,
And if you need to make it work
Put ya hand up .. give him a shout ..
One hot day it was aircon
The hot topic of discussions,
And the man told us, indeed, gave us an education
On nipples and Johnsons ..
Edited by THE34T
  • Like 2
https://www.sau.com.au/forums/topic/30059-spotted/page/910/#findComment-7149638
^^^ brilliant
Spotted Jezz and Rosie in Charny, at around 6. I was cammoed in the DD Focus, I saw the sneaky look you gave Maccas ;)
Hahaha ! I saw some Asian fella just standing there and was eye-balling him :P But a Frozen coke would be so good. @$4.10 for a large frozen coke is not worth it until it's 30+ :(
https://www.sau.com.au/forums/topic/30059-spotted/page/910/#findComment-7149698
Was good to chat Anfanee
Finally finished the 34. and now it looks like it may spit and then dust storms. Gotta love it
Yeah. All we need when there is no rain is for someone to wash their car properly. Then it will rain.
https://www.sau.com.au/forums/topic/30059-spotted/page/910/#findComment-7151141
Spotted the Trojan White StageA and what looks like Troy's old Midnight Purple 33 GTS-t (GTR wing and Rims) parked outside a house in a suburb in this town. ;)
I saw a m'nite purple 33 in Qbn yesterday, haven't seen it around before .... couldn't see details, he/she was giving it a bit and I was a pedestrian .. :ph34r:
Edited by THE34T
https://www.sau.com.au/forums/topic/30059-spotted/page/910/#findComment-7153361
white 33 leaving woden heading to tuggeres, today
silver 34 going past tuggers last night or the night before?
white 33 no front bar heading for maqurie pass (not sure how to spell it)
grey 34 on kings hwy yesterday
white 33 black rims on kings hwy yesterday
white 33 gold rims (pat?) in Calwell twice on sun/sat
black 33 gold rims again in Calwell last night spooling and fluttering like crazy - didn't go anywhere for the noise
then saw my own skyline in woden, mum took it ....
https://www.sau.com.au/forums/topic/30059-spotted/page/910/#findComment-7153795
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
