Meanwhile, yesterday heading out of Ellerston Avenue in Isabella Plains onto Outtrim Avenue in Calwell spotted Aurora behind me while I was waiting at the round-a-bout, a wine red r33 gtst which had made me stop at the round-a-bout which then turned into the cricket nets at Calwell, and then the street behind the cricket nets coming onto Outtrim Avenue, a white r33 gtst with chromies... so much skyline goodness in a 30 second period :rofl:
https://www.sau.com.au/forums/topic/30059-spotted/page/13/#findComment-726622
I used to have a HKS Super Power Flow pod filter mounted at the very bottom of my car and damn that was loud - Those mushroom style filters are the go if ur into ear piercing induction. Don't have it no more :P Its now flat as a pancake (long story!) Bloody hard to replace as the kits are either ordered direct from Japan or get em through BD4's who are the only HKS dealer (charge a fortune) I think Unique used to have em as well but other than that very hard to get.
https://www.sau.com.au/forums/topic/30059-spotted/page/13/#findComment-727833
That was me!  Yeah just there with a mate. What car were you in Sigsputnik? Can't imagine how me missed another line turn up?
I was in my silver R33, but was only there for about 8 seconds. Run in, drop off The Italian Job, run out. Isn't Canberra small!!!! Would have been good to meet.
I dig this spotted thread a lot. :wavey:
https://www.sau.com.au/forums/topic/30059-spotted/page/13/#findComment-728223
Cool! Come out to tha next cruise, that way we won't have to run into ya at Video Ezy!!!!
On the spotted front: Today around 3.30pm on Sulwood Dr. a black R32 GTST , gave the man a fist pump and got jack in return (ok so I wasn't in the Skyline so maybe had something to do with it.)!
Earlier today on Melrose Dr. a dark blue R33 GTST which i've also seen at Tez a number of times.
.......Also, not a spotted but will put in here anyway, last Friday night coming home from Civic my mate Phil in his 32 GTST got chopped by MickGTR on that big roundabout that goes past Woden Pitch n Putt. Lol, Mick's kill roster 1. Ferarri F355 2. Phil's R32 GTST... J/k. It was a brave effort!
https://www.sau.com.au/forums/topic/30059-spotted/page/13/#findComment-729368
oh man thats yours?!?! that thing was sexy as hell... you rocked up to a Mobil service station in the city and asked us for directions (we were standing at a pink falcon xr8 with gold simmons, with a white r32 gtr and black r33 gtst parked behind it).
Damn nice man, I dont know what it is, but your car was just like pwoah!!!! :(
https://www.sau.com.au/forums/topic/30059-spotted/page/13/#findComment-730001
hi fellas,
next time im in canberra will log onto this post, if you see a charcoal grey 96r33 gtr vspec with gold volk rims thats us.....
was cruising last weekend couldn't find no -one to play with :( cept a supra with a burnt out clutch......
Your lucky I was down the coast,
https://www.sau.com.au/forums/topic/30059-spotted/page/13/#findComment-730005
yeah man that was me, saw your fist pump, but thought "WTF whos that?" ill give ya a wave next time!
https://www.sau.com.au/forums/topic/30059-spotted/page/13/#findComment-730500
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
