Spotted said 2 cars above take on black porche -commonwealth ave circle + bridge
He took off at the lights without warning but the boys reeled him in pretty quickly :w00t:
Cant let Porche have bragging rights :P
Put the Porsche back into place :)
https://www.sau.com.au/forums/topic/30059-spotted/page/965/#findComment-7434294
Spotted a maroon 33 gtr on yass road. Exchanged waves :D I've actually seen the car for sale on carsales.
Had a chat at some lights to a dude in a big old school Chevy pickup truck with a cammed v8 doing a formal run.
Was tailed by a guy in a stock white 34 gtt. Had a chat to him at a set of lights. Unsure if he's on sau.
Good day for a cruise :D
Haha I think that was me in the 34 man!
Just bought it from Brad on the forums here.
Close to stock, has nismo suspension and a boost controller due a to a faulty solenoid, but it's only set to like 8PSI.
I sold my old buggered Silver R33 just before I got it, so saw you and was like oh hell yeah.
https://www.sau.com.au/forums/topic/30059-spotted/page/965/#findComment-7434350
Hey Pete, nice to meet ya! Looks like a good tidy car. Mines actually up for sale at the moment haha
Always a pleasure cruising with skylines though. Hopefully we'll see ya round :thumbsup:
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/965/#findComment-7434504
Spotted a black R32 GTR who parks under Nishi, anyone working there from here? See you leave at 4:40pm today. You'll soon be spotting Rosie there too :)
Edited by RosieR34
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/965/#findComment-7435149
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
