Heap of Lines at Woden Last night for the Kill Bill 2 release..
inc one red R33, pretty low, nice rims, sticker on the back window (forget what it said now) and possibly the worst park I have ever seen, looked like he entered the spot sideways, hmm seamed like a lak of respect for his ride oh well it still looked nice.. also saw a Grey R33 with Black/blue Tri spokes, also looked nice was Hella loud too..
https://www.sau.com.au/forums/topic/30059-spotted/page/21/#findComment-797245
saw that yellow R33 with the stickers parked at the Curtin shops at about 12.30am, then 10 mins later as i was pulling out of BP Phillip I saw it again driving along Melrose. Drove behind him for a while..
nice car, not too keen on the silver fuel cap though..
https://www.sau.com.au/forums/topic/30059-spotted/page/21/#findComment-797881
Spotted a whiteish (stucko) 32 GTR (plates GTR 94V) with nice NISMO graphics on its intercooler.
He was cruising thru QBN Monday around 2:30pm and had a Supra behind him and there was a shmick 3000GT around the corner probulary cruising with them.
Was there a cruise on Today?
https://www.sau.com.au/forums/topic/30059-spotted/page/21/#findComment-801973
saw a white 33 comming past the airport sweet mags and a big HKS sticker on the back window she looked at me i just smiled also got a big wave from WHYTRY in belco today good seein u on the street again its been a while
White skyline at the lights near the shell servo at tuggeranong around 6pm. Anyone here?
https://www.sau.com.au/forums/topic/30059-spotted/page/21/#findComment-804798
spotted a what looked to be custom blue paint job like a lighter blue S1 R33 with its front bar missing and a big phat front mount their instead :rant: looks reasonably nice this was on the way to work this morning had a jracing sticker on the window like half the skylines in canberra
https://www.sau.com.au/forums/topic/30059-spotted/page/21/#findComment-809548
SPOTTED: At the BP in Phillip yesterday around 5:45pm a Burgundy R33 GTST with GTR kit - I was the Gunmetal R32 on the otherside of the pump. It was kinda awkward as it looked like we both wanted to say hello but didn't. Everytime i went to give the thumbs up you looked away. My bad! Nice car tho....
https://www.sau.com.au/forums/topic/30059-spotted/page/21/#findComment-809638
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
