boys boys boys word of warning i just got home from a ride in the black sparkles twin turbo walkinshaw and if u are along side him be careful cause this car will put up a slight challenge i cannot describe how that felt it actually hurt the Gs were that bad would love to cruise in a line that powerful it was really crazyness
https://www.sau.com.au/forums/topic/30059-spotted/page/30/#findComment-862394
Fair nuff. Hey, Kdawgboostin33, do you live anywhere near Conder? I've seen a blue Series 1.5 going up and down my street, mostly late at night...
Hey man,
Nah I live on the Northside.............I have not seen any other 33's in Bayside Blue around in Canberra. I know bout 1 R32 - Mine has a FMIC with SIGNAL on it. How is ur ride going??
https://www.sau.com.au/forums/topic/30059-spotted/page/30/#findComment-863473
spotted yesterday evening just b4 5 on william hovell dr. white R32 GTR flew past me, i thought it might have been niks but it another ride, big exhaust, very sexy dished rims (gold centres) looked awesome!!! i was gonna boot it and have a run as it flew past, but with all of the traffic it wasnt a good idea. would have ben fun though, it seemed quick.
https://www.sau.com.au/forums/topic/30059-spotted/page/30/#findComment-868981
Nik's has 3 spoke rims
- yep - guy you mentioned above has whooshed past me a coupla times as well - always around home time in the afternoon and way too much traffic..... :headspin:
There is at least two white GTRs that live in Belco - and I think there is another one that works there...I see him heading the opposite direction (towards Civic) in the afternoons
https://www.sau.com.au/forums/topic/30059-spotted/page/30/#findComment-869018
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
