Yay!!!!!
Ive been SPOTTED!!
yea that was me....i hope... Purple with body kit?????
Yea thats mY spot! :wassup:
YAY i knew someone onhere had mentioned a purple R32! :P
and yes it had a body kit...a nice clean one, not a full on over the top one - sound like yours?
that's the BEST place to park, nice wide spot and only one car next to you :)
https://www.sau.com.au/forums/topic/30059-spotted/page/50/#findComment-982950
YAY i knew someone onhere had mentioned a purple R32!  :cheers:
that's the BEST place to park, nice wide spot and only one car next to you :D
Yea thats me:D
Yea, wasnt too sure about the kit, Friends like it , and they tell me to keep it. so its gonna have to stay for a bit.
"Spotted a purple R32 GTS-t around Tuggeranong at about 2:50.... looking/sounding good."
Oh SIC!
I was spotted again...
Yea was kinda bored at home so felt like goin for a drive...
Thanx Mate , ;)
Kinda wondered what people think of me car, and whether it sounds ok...
https://www.sau.com.au/forums/topic/30059-spotted/page/50/#findComment-983466
spotted a gunmetal R32 (could have been a GTR not sure) at 2pm... i was on Beasley St Mawson waiting to turn onto the Rd that goes past Isaacs, gave him a small wave as he went past, no response :P
caught up to him at the lights at the hospital, was an asian guy...he still didn't wave, looked a bit confused actually LOL
https://www.sau.com.au/forums/topic/30059-spotted/page/50/#findComment-983743
spotted... a datsun tearing me a new asshole because my clutch is stuffed and he tried to take advantage of it :) 7000rpm and one dirty as smell later, i finally got moving... doh :)
On a good note though, hks twin plate arrived on tuesday :P
https://www.sau.com.au/forums/topic/30059-spotted/page/50/#findComment-984060
Sorry shell, didn't know you waved, Im always daydreaming, Hi
anyway :( , Ive only had the gtr about a month, have had no
end of headaches with engine and turbo problems, should all be
sorted in the next couple of weeks though. woohoo!.. Ive been
spotted already :headspin:
https://www.sau.com.au/forums/topic/30059-spotted/page/50/#findComment-984418
anyway    :)  , Ive only had the gtr about a month, have had no
haha that's cool...nice to see you join up here anyway - welcome to SAU! :P
sorry to hear you've had problems :P
where did you get the car from?
https://www.sau.com.au/forums/topic/30059-spotted/page/50/#findComment-984790
Spotted a white R32 in Queenbeyan, the driver was watching the car as he went past, i waved but dont think he really cared. was probably getting over the shock of seeing my mum behind the wheel...
Also spotted a yellow R33 series I with stripes up the middle. No offence to the driver but i'm really not a fan of the stripes...
https://www.sau.com.au/forums/topic/30059-spotted/page/50/#findComment-985888
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
