Looooong story... Been at the Hospital since 2:30am with the EX. :(
No work for me today!!! :D (and if the Bosses decide to play by the rules for a change, I might just get paid for it too). :P
Oh gosh, hope everything is all good. But sounds like a good deal if you get the day paid off.
I had the last 10 or so days sick 0 pay. All my bills came in this week. :(
https://www.sau.com.au/forums/topic/30059-spotted/page/851/#findComment-6915957
Thanks Mate, yeah she has an ongoing issue (gallstones) and is on a waiting list for surgery but still waiting...
No number of visits to the Hospital will speed up the process either but in the meantime, when it hits it hits hard. :(
Sux when you get no benefits like sick leave etc when on contract or casual or whatever.
I am Fulltime though. Hopefully my carers cert will see me thru.
https://www.sau.com.au/forums/topic/30059-spotted/page/851/#findComment-6915970
Farout man, that's cray. Dad had his Gallstones taken out a few years ago and said it was the most painful thing he has felt. Yeah it does suck man. I went from full benefits to 0 in a space of a day haha. Get some rest man.
https://www.sau.com.au/forums/topic/30059-spotted/page/851/#findComment-6915989
yeah, my wife went through the same thing - we ended up going to Goulburn for the operation as it was done about 3 week after getting on the list (win for Goulburn :) ) see if you can get in elsewhere...
https://www.sau.com.au/forums/topic/30059-spotted/page/851/#findComment-6916059
there's also a different white R33 GTS-t at Prestige in hume
Looks like the repair bill will be greater than vehicles market value :(
spotted another white 33gtst a few days ago with minor damage on left side of front bar.
also a 34 which should be out soon :ninja:
https://www.sau.com.au/forums/topic/30059-spotted/page/851/#findComment-6916167
Everyone hiding their cars?
Saw a yellow(?) 200 going sideways pulling out of civic (Near Aldi carpark). By Sideways I mean churped his tyres which pulled his bum out for a moment.
Edited by RosieR34
https://www.sau.com.au/forums/topic/30059-spotted/page/851/#findComment-6921756
Forgot I spotted THE-34T on Sunday in QBN at the intersection with the Shell and Caltex servos on opposite corners. I think I was on my pushy at the time lol
I knew I should have waved at that dude on the pushy!! ... Lol
Thanks mate, at least you didn't kick my door ..
https://www.sau.com.au/forums/topic/30059-spotted/page/851/#findComment-6923797
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
