Hi all, wondering if someone can help me out. I recently installed 2860-5 on my R34 GTR along with hks dumps, power fc, sard 800cc injectors and 044 pump. Got the car tuned at croydon racing, the car made 304.4kws at all 4 but i dont see boost until 6500rpm!!! This seems way too high and think there maybe a problem somewhere. Things i have checked so far:
- disconnected wastegates and drove incase gates slightly open (gates ok)
-checked for boost leaks (none evident)
-drove with no cat incase blocked (not blocked)
I have spoken to a few people and they say that they are seeing full boost by 4000-4500rpm.
The engine is stock (no cam gears or cams) but was told they shouldnt make too much of a difference especially not 2000rpm!!!
Any help much appreciated
https://www.sau.com.au/forums/topic/300613-2860-5-too-much-lag/
  • Replies 74
Disconnecting the gates is not going to do SFA.
What did you hope to achieve by doing this and what happened when you did?
You need to adjust them with correct pretension.
lol ye exactly. All it will do is let them blow open soon as they see pressure... pointless excercise that was.
If anything you should be wiring the gates SHUT to see if the actuator setup is your issue.
Did you use NEW/HD actuators? Or the ones off your factory turbos? Cause the factory turbo's ones... no good.
That sounds like the issue, i bet you wire them shut, boost comes on hard and around the 4000rpm give/take which is clearly actuator setup related.
Oh ok did not realise that they needed to be wired shut, will give it a try. They are the the standard wastegates that came new with the turbo's (purchased from gcg) so not sure what the springs are preset at, does anyone know?. This definitly sounds like it is the problem though, thanks heaps for all your help, will keep you posted.
cheers...
I just bought the same turbo for a r32. Look forward to hearing your results. But like someone else said 'What did the tuner say'?
Also what boost pressure were you running?
Also you wanting to sell your stock R34 GTR Dumps?
Edited by gtr fan
When i took the car to croydon i told them i wanted 300awkws which it achieved, i did not see boost vs rpm dyno sheet only power. I called them and explained to them that it was far too laggy, they told me to check a few things and if they dont work bring it back to them as the wastegates may be set wrong. The car is tuned at just over 1.2 bar using turbosmart t-piece (bad choice i know) but before i had the car tuned with just bolting the turbos to the stock motor and no t-piece, it still wouldnt hit full boost till 6500rpm.
I have just tried to tighten the wastegate rods but the rods have a crimp to stop you adjusting them, any ideas?
Also called gcg, they told me they have never heard of this before and i should be seeing full boost at roughly 4000rpm. They told me they are 1.0 bar actuators standard on the 2860-5's.
Edited by trvgtr
Just remember to back off when you've hit a bar or so, you dont want to risk blowing the motor. Also depending on how the tune is, bringing the boost on earlier may get you into dangerous territory. It would be worth checking on the dyno.
Might be easier to just disconnect the signal to the actuators first. If that fixes it then your boost control is stuffed.
You know you'd have much less lag with -9s right?
300 at the tyres and you decided on -5's? ugh... -9's are the turbo for 300-330rwkw!!! People still seem to fail to understand or research correctly.
-5s are 400rwkw turbos. Not 300.
With 9's I have boost building around 2800rpm, by 3300-3500rpm im hitting 1bar. Happens to fast for me to take notice anything after that being RWD, gotta pay attention.
If you are only making 300 on what, 16psi... thats a bit harsh. I'm sitting around 280 on 16 with smaller turbos, and better response (when compared to working -5s).
And ive only got a half baked tune in there at the moment because i haven't put injectors/afm's etc onto it yet...
Just so people know, as Trav did not word it properly... He disconnected the pressure lines TO the wastegate's, he didn't actually disconnect the wastegate's, so he was eliminating the possibility of a fault with t-piece/turbosmart boost valve.
Therefor the wastegates were closed the whole time as they did not see any pressure, it was still laggy.
His wastegate rods cannot be adjusted/pre-tensioned, they seem to be preset and locked in via crimping.
1.2bar = ~17.4psi
I would of thought having it dyno'd at croydon, if there was something obviously wrong such as being way to laggy, they would of mentioned something or called him up saying... listen, we noticed a big issue with turbo lag and we need to check it further etc etc...
Can someone tell me what the rb26 likes in the way of timing? @4K and >above ( @17psi)
You havent got it quite right either - the lines are connected to the actuators not the wastegates :-)
Fair call.
How do you work that out?
Removing the line simply lets them run off the actuators, if still connected.
That will not hold them shut.
Therefore it is not as you said, closed the whole time, it is still riding on the actuators being setup correctly to stay closed.
Something that is yet to be confirmed and the most likely cause at this stage.
Totally depends.
If you are given a car and told specifically to tune it, you do that. It sounds like they didn't do any of the work on the car either.
I've seen many a workshop go above and beyond only to be hammered later by silly owners complaints.
Not saying this is the case here at all, just another perspective to look at because we clearly do not have all the facts thus far. Lots of pieces missing.
Yes, leaving them run off the actuators, wich GCG told him are set at 1bar and prest already to correct tension.
I dont know what the pretension is or how much it should be, but you cant adjust it the way they left it/locked it, so its set to the way they want it ( but like you say, doesnt mean the pretension is set right from factory ).
We tested the actuators and they start to open at 15psi, so they are closed at least till 15psi or so with line pressure to them.
And there is a fair bit of tension on the wastegate flap keeping it closed by the rod/actuator, but is it enough tension? i dont know.
How much tension should there be, is there a set rule/testing procedure for that?
Edited by mazman
You are starting to sway me Nismoid with your -9's theory. Lean on them enough, E85 (or race fuel on the track) with built engine and appropriate headwork... 350kW, maybe? Full boost 3.5k and rev to 8k only for reliability, less stress on every other part of the drivetrain...
Anyway, don't stress and do something silly, take it to your tuner and tell him what is on your mind. Ask dumb questions otherwise you won't learn.
You can get 330rwkw on PULP, its the same as GT-SS which is what i have now :)
I only rev to 8k as well. Its certainly still pulling nice and hard. Obviously it's not the pin you to the seat feel of turbos of much larger size, but its not 'dying' out either way.
I wish i had my setup done so i could post up some results... will be Feb/Mar before i get it back, few delays with overnight parts from Japan.
If you cant make 360 on E85 i'd be nothing short of surprised in all honesty. On a good motor, they would be sweet.
Im doing it all with just factory cams, and a minor head tidy up as well, nothing big and costly in the head.
Depends how much power you need for the circuit though. A built motor, nice safe tune and 350-360rwkw with response to boot would be very nice.
But then -5's smashing 400rwkw on PULP is also very nice :D
Totally depends.
Yes i agree with you, Iam not blaming croydon at all, i done all the work myself and took it to them just for a tune thats it. Iam taking it back there tomorrow to see if they can sort it out, will keep you posted, cheers...
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
