Guys,
After being excited about my new turbo purchase...i am quite disappointed.
Would appreciate any advise.
In short, This is what i purchased as advertised. (from a supplier who ordered from another supplier i believe)
Garrett GT3071R RB25DET T3 Bolt-on Turbocharger 500hp, Dual Ball Bearing Kit - 0.82a/r
Horsepower: 500hp
Compressor Housing A/R -: 0.60a/r
Compressor Inlet -: 4"
Turbine Housing A/R -: 0.82a/r
Turbine Hsg. Attachments: Inlet: Standard 4-bolt T3 flange
Turbine Hsg. Attachments: Outlet: Nissan 6-Bolt
Oil Inlet - : Inverted Flare 7/16-24 thread
Oil Drain - : Standard 2-bolt T3 flange
Bearing Type: Dual Ball Bearing
Cooling: Water Cooled Centre
Wastegate: Integrated Wastegate
Includes:
1x Garrett GT3071R RB25DET Turbocharger, complete High Nickel Content Cast Iron Nissan Style Turbine Housing with Internal Wastegate and actuator.
Fitting Kit Includes: Oil Drain, Oil Lines, Water Lines, Turbo Gaskets, Spacer, Studs, Nuts.
Turbo was delivered direct to my tuner, who had spent approx 9 hours labor to install, and needed to purchase the following.
4x studs - apparently the ones provided were not long enough or universal instead of metric.
10m spacer as it was not included.
An earls adaptor for the water or oil line i believe. (Lines were provided with the kit)
2x turbo hoses and clamps
also something about re-aligning the compressor housing??? i think. did mention he is surprised they were not using jigs
Picked up my car today after not having it for 8 days or so.
car is making 243kw@tw on 14psi
I looked at the new turbo, and can see the following.
compressor housing .50 A/R
garret ID tag: GT2835 - 700382-003
researching the above, it is the cropped version?
So all up, i have paid for a product i was not delivered with, and spent many extra $ to make it bolt on.
PS. my tuner was not aware of the turbo being delivered, he only knew one was turning up and needed to be installed.
Anyone else had an experience like this and what have you done about it? or, what would you do in this case?
https://www.sau.com.au/forums/topic/301930-my-turboa-good-thing-or-a-bad-thing/
Hopefully it isnt the cropped version.The results seem good for the boost being run. IMO there is no advantage having the 4" intake as opposed to the 2.75". Pretty much all the other bits needed are common knowledge for fitment. How much was it?
def think its cropped from what i read.
$2460
thanks for the replies guys.
the numbers are confusing the hell out of me.
I am just concerned that i have not been provided with what i ordered/paid for.
so, my turbo is a .50 compressor, turbine 700382-003. and looking at the rear it has "sonic" written on it.
looking at the sonicperformance site, they state they have a .64 turbine housing.
and on the site from which i ordered it, the specs below differ.
The GT3071 - 20 is the same as a HKS 2835
so you got the turbo you ordered. The power is good for that booet on that turbo IMO
What exactly are you not happy about?
he is not happy about the following...
he added Red Bull to his skyline...cost...$3.50...result...supersonic multi million dollar jet fighter.
he then tried a different turbo...cost...$2460...result...243RWKW to remove the skin off his custard.
Id be pissed too!!
Moral to the story...drink Red Bull and dont eat custard!
Gt3071 is basically the same as the hks spec Gt2835 so going by the id no. it seems to be right.
The rear however will be cropped to fit the Nissan style flange and its highly unlikely it would be a .82
The comp housing it supposed to be .50 a/r as well for the Gt3071, the Gt3076 however comes with the .60 a/r comp
That power looks good for 14psi tho....20psi should get u up to 270ish
They don't crop the turbine to fit the housing. They machine the housing to suit the turbo.
It will be all the same specs as the 3071-3 that the ID tag says. The turbine housing A/R is 0.73.
$2460 is spot on the money considering it didn't come with spacer, studs or silicon.
Who did you buy it from?
Keep in mind that the ID tag has nothing to do with housings. It only identifies the cartridge.
All the specs I said in the above posts are accurate. I sell these as a sonic dealer myself.
thanks again guys.
i am actually happy with the power and performance of the turbo...
below is the site
http://www.tweakit.net/shop/product_info.p...9ij7uter43vvdj6
didnt come with the silicone reducer etc... which i am fine with. but think it should at least state "misc parts may be required to fit"
spacer is listed, but wasnt supplied, cost me another $30 for part + delivery. then some labor to grind.
water line and oil line was supplied, but required an adapter for some reason, cost me an extra $30
studs were supplied, but didnt fit. cost me an extra $45
also required an elbow
and as mentioned, the tuner had to re-jig the alignment...or something like that.
so a few extra $ and hours in labor i had to fork out for.
would i be correct in saying that the site is incorrect? false advertisment
Id be pissed too!!
paul, just because you cant use e85 in your car doesn't mean you have to drink the rest of your stock
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
    • Yes, well. Mine are less than half that. ARBs are not set to "dumb" either.
    • I would hope. But, we all know even the best companies have an issue sporadically.
