Hey,
When i apply the brakes, my brakes start to squeek and its getting annoying, ive changed the pads. got new rotors about 4 months ago. tried "Squeek stopping spray" and nothing is working, i grinded down the edges of the pads and still nothing.. Im not sure what to do now? maybe take to a "pro" to look at it? =\
https://www.sau.com.au/forums/topic/302978-brakes-squeeking/
  • Replies 48
Hey,
Check the toe in and toe out alignment of the pads. Also ensure that the backing plates are still installed behind the pads.
You will want a very slight toe in on the leading edge of the pads to stop squeaking from memory.
Nigel.
Its a case of trial and error for Skyline brakes im afraid.
I couldnt tell you how many times i tried to get mine to stop squeaking, and failed. Even with stock pads.
Tried EVERYTHING and eventually, they squeaked again..
Skimmed rotors, shims Ferodos..
New Rotors, shims stock pads + brake squeak stop
New Rotors, no shims squeak stop... and so on and so forth.
Finally, what worked for me, was getting slotted rotors. Have had them on the track, and 100's of km of town driving and have not heard a peep from them since. This is with Ferodo Formula pads, and NO squeak shims.
I think the squeak was more to do with pad glazing in my case. And the slotted rotors are keeping the surface clean.
Well thats my theory anyway :)
Edited by gotRICE?
Hey,
Mine only squeek when it has been a cold day. Usually after about 5 minutes though they stop. I've tried hosing the brake dust off but this made them worse at the time. Now I just put up with it for 5 minutes and then it goes. I don't know what they theory is there, maybe something to do with disc expanding in heat whcih causes brakes to stop squeeking?
ethier that mate, or the pads are getting up to temp after 4 or so mins of driving,
My gtr's brakes squeeeeek there heads off, give it 10-15mins of hard track like driving, and bam there quite, than when i go back to crusing they cool down and off gose with the squeeeking again,
It depends alot on your pads
  • 3 months later...
Sorry to resurrect a semi-old thread but I've had my R33 for about 3 weeks now and have tried a bunch of things to stop the brakes squealing, it's quite loud and very annoying.
Mine has slotted rotors, which I've had machined, Bendix Ultimate pads in the front (new) and Ferodo Formula pads in the rear (also new), shims are also in there. My next plan is to use different pads and see if that changes it.
When I had the rotors machined and pads changed it was all good and quiet for a few days, now it's just as bad as it was before.
Any new ideas?
Certainly did. I paid particular attention to making sure i did that. It's so annoying, I love the skyline and should have bought one much earlier but then there's this terrible noise every time I brake, quite disappointing.
ferodo formulas squeak like a bitch on the back. I had them on front and rear and i swapped the rears out for another brand (TRX?) which were slightly better but still squeal. I'd try a softer pad on the back, they are not as critical as the fronts. I'm trying QFM HPX's next front and back (their street pad).
yep GSL Rallysports do, and I put some on mine, no squeaking apart from a tiiiny bit on very hard braking. Given that I put on slotted rotors with only a little bit of use, and didn't bother machining the rears I'm stoked. I didn't have squealing on the OEM pads before though either.
QFM are a really good pad for the money IMO, but that's going off on another tangent..
Interesting reading these postings. Most people with brake noise seem to have done the right thing and machined discs and fitted their new pads with the factory anti squeal plates but the brakes still give them problems. The problem has to be pads that are not appropriate for the use of the car . Using pads over 400c on the street is wasting you money and wearing out your discs. Using pads with high temps in normal driving conditions which the majority of people do actually makes the brakes perform less efficiently than a standard pad and yes you get noise. High temp pads should only be used in circuit conditions. The only exception to this is hillclimbing where you use the softest pad available.
Maybe you have misaligned caliper pistons something caused by the wrong technique when resetting.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
