OK, so time to get ready for the first round of the Sprints next week, thought i better pull thumb out of my bung hole and get a few things done to the R35. I've primarily made an effort to host these pics for the USA guys (who may be a bit aprehensive of playing with their GTR) not to mention pulling bits off / replacing bits etc....
So here we go, let's get some maintenance underway... we need the car up on stands,,, lets get this big bitchola up in the air...
Using trusty "mini-ramps" (thanks Dave) lift the front end...
Once the front end is lifted with the mini-ramps, get your floor jack under the front jack point (right behind the oil train port as per below..
Lift that sucker way up, ready for your stands...
Position your jack stands at the side jack points, left and right (fronts)
You may need to bring the car down slowly to make sure you have the jack stands positioned properly. You want to end up with something like this..
Now with both left and right (front) in the air, get your jack stand positioned under the rear centre jack point (just under the rear transaxle) such:
Lift the GTR up, position the jack stands just like at the front and lower slowly until you have it all positioned correctly on the rear jack points..
You should end up with something like this, ready for some well due maintenance..
I've found this is the best way to go about it, assuming you are doing this in your own garage.
Now.. let the games (and skinned knuckles) begin..
So... moral or the story is, give it a go,, it's just a car after all, and fark the warranty, fark it right in the eye with a blunt dick i say.
(more to follow)
https://www.sau.com.au/forums/topic/303133-my-r35/
  • Replies 71
good to see . nice plate too
got a list of things your doing to it ? or do we have to wait and see
replacing most fluids (pretty hard to get to front diff!), installing new titanium exhaust (*in pic), some new diffuser blades, some carbon fibre intake snorkels, and a few other things. yep there are heaps of covers under there,took my an hour or more to screw around getting them all off, half the battle. pita. the creeper makes things a LOT easier too.
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5025171
I'm loving the look of that Exhaust.
BTW those mini-ramps are ingenious. Ive never come across them before. Where abouts can you get them? Ive always used a scissor jack behind the wheel to get it high enough to slip the jack under.
Looks like some pretty good design under there regarding aerodynamics. Must be a pain taking it off to do any work though.
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5025495
I think you can buy them at most caravan dealerships (the mini-ramps) believe it or not. Otherwise a block of wood might do instead.
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5025510
Wow, you learn something new everyday... Who would have thought a caravan shop would have something that is actually usefull?
Can also get them from ebay too for those (like me) that wouldn't know where to begin looking for your local caravan shop :happy:
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5025532
wow good to see someone who is not afraid to give it a go.
also did you start her up without the exhaust??? lol
Good point, but I think they are fine, all I am really worried about is it falling on me whilst working under the car itself (!). It's a good idea to use the floor jack too, under the central jack points (front or rear) if you are working under the car. That way you aren't depending on just one stand/point alone.
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5027281
Great to see you having a go doing everything yourself.
Did you have to take the wheels off to put the exhaust on..? :ermm:
Or you doing a brake upgrade as well?
I am doing brakes too so took the wheels off. I think you could do it with the wheels on if you wanted to.
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5027588
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
