Fvcking joke!
How is defecting cars keep the road toll down?
That is the biggest, lamest, excuse and they ain't doing themselves any favors.
>_<
Come on people WTF! Your first clue is "centre" mispelt as "center" in the first line of it. I thought us Skyline folk were smarter than this!!! :P
BAHAHAHAHHA what a tool! goes to show...even the people enforcing the law slip up... i dont believe he got fined n crap its just to make the public happy... i think due to human error.. at least 5 kays over the limit should be ignored.. not like 3 kays..
neway that's just my opinion.
How come it's 3 points for 10km over?
I thought it's only 2 points for 10-15km over the limit?
Used to be that way, it's not 3 points for over 10km/h.
The idea behind 3km/h is a threshold for incorrect speedos. According to the law you shouldn't be anywhere near the speed limit as it's just a limit and not the speed you're supposed to be doing, i.e. approximately 5km/h under according to TAC advertisements :blink:
From the Herald Sun article
"On this occasion I was very lucky - I didn't drift into a tree, I got snapped (by a speed camera).
Exceeding a posted speed limit ≠ drifting into a tree.
Normally I dont insult people on a personal level but this guy is a downright moron. I shudder to think how he could further ruin the state. I couldn't write a fictional article with that level of stupidity and idiocy within.
Edited by Bozz
"I need to be more aware. I'm luckier than a lot of Victorians who weren't. I'm still here to talk about it.
"Lots of people die in exactly those kinds of circumstances.
"It's been a valuable lesson for me."
that made me lol
Yer i read that and i was thinking the same. What happens if its 20 km over u fly off a cliff lolz to this bad
think he was saying that he was tired from driving in the country town, so he didn't notice the sign. and apparently that lets him preach about dozing off at the wheel which could result in people going into trees.
christ. nooblet got a speeding fine for going 10 over. way to turn it into something totally non relevant.
i better not type any more, cos my key stroke could distract the fly that carries the bacteria which could mutate into zombie flu, making it land into my co worker's coffee, thus starting a chain of reactions that will result in a zombie apocalype.
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
