  • 2 months later...
Anyone else turn up to the last minute meet today? When I got there it was just me and an SS Commodore who went through two red lights to get there. I didn't want to be seen around that kind of behaviour so I left after he issued me with a minor defect notice.
Defected. No fine or NOU, just need to drop in on the pits for an inspection when I get the items changed. Cop was pretty fair/nice about it all and he could have got me on a few other things, but the targeting / chase down and subsequent blocking of one lane on a major highway to do so was pretty ridiculous given I was driving more sedately than anyone around me. The surrounding traffic must have thought it was a stolen car or something.
Saw a white R33 pass me while I was on the side of the road, anyone from here?
HIDs. Yeah minor, but fark, aside from inconveniencing me half an hour I gotta change the item and then find the time to go to Vicroads. I'd sooner have paid a fine for speeding and not have my time wasted doing all that. No reason for being pulled over other than it being a Skyline. Story of the import driver's life.
over 24 hours and no moron has come in here and told adam he is over reacting and that skylines dont get picked on... weird...
Usually people who have never been pulled over when they were doing the speed limit, by a cop who did a U turn or ran a red light (or two) to do so :cool:
Paraphrased quote from someone on here who got defected by the same car as me on the same day and contacted me in regard to it: "they said every Skyline they pulled over today expressed that they are car enthusiasts and not hoons." Whether that's in a good or bad sense, fact remains they were pulling over Skylines left, right and centre for the sake of it. I'm not whinging about it because I knew when I bought the car that it had this kind of stigma about it - but yes, anyone who denies Skylines get targeted is kidding themselves lol.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
