  • Replies 846
Posted Images
I think there should be a 250kw limit. If you ain't over that GTFO.
something like eg. 200rwkw dont cut it at a track, but circuit aint just about power.not everyone can afford the same thing, the aim of it is to have fun an improve your times, while getting to know your car better...
well i was in a ke70 ca18det and thats making 140rwkw and that was soooo much fun i have the bug, i know writeoff was in his peugeot and he was ripping it up.
munro turned the boost down on his car and ran a quicker time..
all about driving style and lines!! oh and getting power to the ground!!
+1 :D
dude thats a bit 4UCK!NG harsh isnt it.....not everyone can afford a GTR neither afford a 250kw+ car.....yet i can definitely say that you in you GTR wont be able to beat some people with a lower powered car regarding lap times......its not a drag event where somewhat power does matter....neither it is a drift event....i have always had an appreciation of circuit/grip days a it challenges you in your driving style and definitely helps to know your car a bit better....
i went on the advance driver training day and happy to say that a GTST "fleet ship" kept up with the GTR's
Track day is all about enjoying your car in a safe environment....not about power....who cares about power
Hmmm might have to try and scam an entry into this one somehow....so I can terrorize Munro...in the EVO :nyaanyaa:
Seriously if anyone is dropping out let me know, its a bit tight being so close to Mt Alma on the schedule but sounds like a great day with some nice cars on the track :(
Wow. Change your pads boys. I said that about David wanted people to drop out so Blue32 could make it..
Lol. It did seem a bit harsh so you had to expect that kind of response. And as Adrian pointed out at the last private track day I took my 52fwkW Peugeot and had an absolute ball. I would have fallen nearly 200kW atw below your cut off point.
Already looking forward to this day. Wish I could afford a big brake kit before it though.
I am so keen to get out there, but everytime one comes up there is always something wrong with my bloody car :blink:
Since i am staying at your place, you are more then welcome to come along with me.
I'm thinking of dropping out.
dont chad! show em what ya made of :)
OK MY CAR WILL BE READY BY THIS DATE CAN MODS/ORGANISERS PLEASE NOTE ! IF THERE IS A POSITION AVAILABLE SURE THOSE WHO WERE IN FIRST THEN PLEASE NOTIFY ME AS ILL PAY FOR CLUB MEMBERSHIP AND TRACK DAY FEES THAT NIGHT
a big thanks in advance.. ill also book this day off anyway so i can come down and support everyone and catch up with everybody ive missed..
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
